Will DDR3 1333MHz work in a DDR3 1066MHz Mobo?
  On 16/05/2011 at 00:24, SHoTTa35 said:
Sure, just will run at the slower speed.
Not entirely true, some machines may not even turn on with memory speeds higher than what the board is capable. Only real way to find out is to test it.
Not correct. if the mobo supports up to 1066 and nothing higher then it will not work. the only time that it will run at the slower speed is when you put say a DDR3 800 and a DDR3 1066 module in then the memory will run at the slowest speed err the DDR3 800. to avoid that, put matching speed rated sticks in to run at the highest speed.If you have a mobo that supports DDR3 up to 1333 or PC10600 and you put DDR3 800 sticks in, then it will run at the DDR3 800 speed until you replace the DDR3 800 sticks and put higher rated sticks in, up to the max rated that the mobo supports.
Another thing to keep in mind is RAM voltages. Make sure to adjust your BIOS and set the required voltage (there are printed on the RAM sticks). This is something I did when working with DDR2 memory, but I'm not sure if DDR3 makers are putting out stick with different voltages other than 1.5v...
As articuno1au said, you can certainly overclock you mobo to run them at 1333mhz.
The Mac won't do it because their firmware is locked in place for the memory apple want to use. That's the only reason Mac won't do it :\ Macs are entirely capable of running faster memory -_-
See those Jedec values? The motherboard will pick the first available safe value for the board and run it..
In the case of my memory with your board: Jedec #3 at 533 (dual sided = 1066).
@ Ajua - Yeah, a lot of them require voltage changes. You just have to be careful with Intel's i3, i5 and i7 processors because they don't support voltages above 1.65v for the onboard memory controller :\
I'm running mine higher >.>
:rolleyes:
I agree, any computer that isnt a mac should suppport the ram. PC 10600(1333mhz) is backwards compatible with PC 8500 (1066mhz). However you will be bottlenecked by the slowest component front side bus for your processor, or motherboard. If either supports only a fsb max at 1066mhz, the ram will run at 1066mhz.
  On 16/05/2011 at 00:46, articuno1au said:
Everything that isn't a Mac will run it.
You can also overclock your board to run it at 1333 if you want :)
My x58 only supports 1066 and I have my ram running at 1600 (with really tight timings (How I love thee OCZ)).
  On 16/05/2011 at 01:26, articuno1au said:
/headdesk x 100000000
I meant to systems that don't support it natively you ignoramus.
That was quite clearly the topic of this conversation.
God damn Mac users :\
you first said everything that isn't a mac will run it, i showed you one that will... and the original topic was will it work in his mobo and i spit out an example of where it will not and soldier1st perfectly explained why it won't. you're the one that trolled in and said it won't work with any mac which has nothing to do with the original topic. this has nothing to do with being a mac user, it has everything to do with hardware of PCs, with both macs and windows machines use the same type of computer hardware.
instead of just feeding your ignorance because you didn't read the above posts at all which tell you that it may not work, i'll just quote this one again...
  On 16/05/2011 at 00:44, rajputwarrior said:
^ you are right. depends on the mobo if it'll downclock it. my macbook wouldn't clock ddr3 1333 ram so i had to eff around with the firmware to manual change the clock speeds. only thing you can do is test it.
Feel free to read your first reply to the topic. You brought Macs into it. I was talking about frequencies above the rated values, and was saying that anything that wasn't a Mac would run it. It doesn't mean Macs can't run it, it merely means that things that aren't Macs will.
I wasn't trying to imply it wouldn't work with any Mac. I don't think anyone would read it that way, and if they did, bumpkiss to them.
@ the last part of your quote:
Also note in this reply my statement: "The Mac" referring to yours as mentioned in your first post :\
im glad you skipped the part of why i brought the mac example in and how i said that i was just an example of computer hardware not working with said higher clocked ram speed....
And you blithely ignored the part where I said things that aren't a Mac and wasn't directly commenting on what you said?
Seriously..
This is bordering on the edge of vegetative state stupidity. If you are hung up on my previous post, I'm sorry but that's not my issue :\
Is it just me or do most Mac owners have a MASSIVE inferiority complex :\
I also did not mean that all macs cant run with this ram, I meant that some macs will not run without modifications, because of firmware apple adds to prevent modifications to the machine. Macs do run on the same X86 architechture as other PCs. The only difference is they try to lockdown what can be modified through adding firmware. Apple computers also contains very few parts made by apple if any at all, most is licensed from other companies (intel, ati, nvidia, asus, etc.). Just look what they did to their harddrives.... http://www.theregister.co.uk/2011/05/14/imac_hard_drive_replacement_woes/
Self deprecating sarcasm, that doesn't sound like me at all..
Thanks captain underpants..
Good to see your "points" have come down to personal attacks. At least I am weaving fact and logic into my assertions that you are an ignoramus.
no knows
/cares
who you are around here. and i haven't personally attacked anyone. it's you doing it towards me this entire time with classics like "captain underpants"
on topic: just throw it in the motherboard and see what happens....
Best answer I have seen so far on this thread. Karma++ to tech heads.
