caprireds Posted February 13, 2019 Share Posted February 13, 2019 I connected my audio system PANASONIC SC-AKX70 to my pc sound card through 3.5 AUX Cable ...the system has 2.1 speakers ...but the sound seems to be mono .... only comes from one speaker !! any idea? thanx Link to comment Share on other sites More sharing options...
JohnG86 Posted February 13, 2019 Share Posted February 13, 2019 What do both ends of the audio cable you are using look like? Left speaker only could be a bad cable, have you tried it with another device? caprireds 1 Share Link to comment Share on other sites More sharing options...
caprireds Posted February 13, 2019 Author Share Posted February 13, 2019 I tried connecting,another way, through the line in (in front of the audio system (... and had the same result !! Link to comment Share on other sites More sharing options...
caprireds Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) isn't each end of the cable dedicated to one speaker? so one goes to the right and another to the left? or both of them just MONO? and MONO goes to one speaker whatever... how about the subwoofer?! I use windows 8.1 and navigated to sound options...and tried the setups of 1- stereo 2- 5.1 and more... but no way !! I'm sure there is no problem with the audio system...because I listen to music through usb flash key ... and the sound is full (the best bass and sound I ever listened to, actually..) Link to comment Share on other sites More sharing options...
DevTech Posted February 14, 2019 Share Posted February 14, 2019 50 minutes ago, caprireds said: isn't each end of the cable dedicated to one speaker? so one goes to the right and another to the left? or both of them just MONO? and MONO goes to one speaker whatever... how about the subwoofer?! I use windows 8.1 and navigated to sound options...and tried the setups of 1- stereo 2- 5.1 and more... but no way !! I'm sure there is no problem with the audio system...because I listen to music through usb flash key ... and the sound is full (the best bass and sound I ever listened to, actually..) 1. Which Audigy do you have? 2. The Audigy (and pretty much any 5.1) will have: - Front - left/right - Rear - left/right - sub & center - digital out - input - mic/aux etc 3. for 2.1, you connect the front, and the sub (use another red/white pair but just one gets connected) 4. tell the driver you are using 2.1 Link to comment Share on other sites More sharing options...
DentedAphid7 Posted February 14, 2019 Share Posted February 14, 2019 (edited) Ha I got exactly the same speaker lol I'm at work now so I don't have pics, but you can try the following: I modded mine to have longer wires. But yeah, could be the contact of those wires? If I wiggle mine a bit to certain angle it will have sound out from one speaker. And the red/black tabs are both connected correctly in the right spot? (Try if AUX plays fine through your phone) Are the aux cable at it's fault? If you are using Audigy, make sure the drivers are updated. caprireds 1 Share Link to comment Share on other sites More sharing options...
caprireds Posted February 14, 2019 Author Share Posted February 14, 2019 3 minutes ago, DevTech said: 1. Which Audigy do you have? 2. The Audigy (and pretty much any 5.1) will have: - Front - left/right - Rear - left/right - sub & center - digital out - input - mic/aux etc 3. for 2.1, you connect the front, and the sub (use another red/white pair but just one gets connected) 4. tell the driver you are using 2.1 1- Sound Blaster Audigy SE Link to comment Share on other sites More sharing options...
caprireds Posted February 14, 2019 Author Share Posted February 14, 2019 I put the black inside the green of the sound card ,and both of the red and white inside the aux in behind the panasonic where the Aux in... Link to comment Share on other sites More sharing options...
caprireds Posted February 14, 2019 Author Share Posted February 14, 2019 (edited) 11 minutes ago, DentedAphid7 said: Ha I got exactly the same speaker lol I'm at work now so I don't have pics, but you can try the following: I modded mine to have longer wires. But yeah, could be the contact of those wires? If I wiggle mine a bit to certain angle it will have sound out from one speaker. And the red/black tabs are both connected correctly in the right spot? Are the aux cable at it's fault? the cable is fine ,and correctly connected... when I tried to connect the sound card to the other choice,through (MUSIC PORT JACK ) ,had the same result... it SOUND AS IF MONO !! Link to comment Share on other sites More sharing options...
caprireds Posted February 14, 2019 Author Share Posted February 14, 2019 (edited) Tthere are only two AUX IN ports behind the sound system ,... there is no port for subwoofer.. Link to comment Share on other sites More sharing options...
DentedAphid7 Posted February 14, 2019 Share Posted February 14, 2019 Just now, caprireds said: THE AUX IN ports behind the sound system ,only two.... there is no port for subwoofer.. 11 minutes ago, caprireds said: the cable is fine ,and correctly connected... when I tried to connect the sound card to the other choice,through (MUSIC PORT JACK ) ,had the same result... it SOUND AS IF MONO !! Could be one of those tabs leading to the one of the speakers. Have you tried other AUX cables? caprireds 1 Share Link to comment Share on other sites More sharing options...
DevTech Posted February 14, 2019 Share Posted February 14, 2019 31 minutes ago, caprireds said: the cable is fine ,and correctly connected... when I tried to connect the sound card to the other choice,through (MUSIC PORT JACK ) ,had the same result... it SOUND AS IF MONO !! If that is a picture of your real cable, it is NOT a stereo cable. It has an extra wire for microphone, typical of cell phones... Link to comment Share on other sites More sharing options...
DevTech Posted February 14, 2019 Share Posted February 14, 2019 25 minutes ago, caprireds said: Tthere are only two AUX IN ports behind the sound system ,... there is no port for subwoofer.. So you were incorrect, you do NOT have a real 2.1 system. You only need stereo from the Audigy GREEN to your miniature stereo system. Try another cable. Make sure the Audigy driver is set to Stereo (2.0) Then make sure the player on the PC is set to the Audigy speaker output and not the digital output. caprireds 1 Share Link to comment Share on other sites More sharing options...
DevTech Posted February 14, 2019 Share Posted February 14, 2019 2 hours ago, caprireds said: I connected my audio system PANASONIC SC-AKX70 to my pc sound card through 3.5 AUX Cable ...the system has 2.1 speakers ...but the sound seems to be mono .... only comes from one speaker !! any idea? thanx Also, What player are you using? And what type of file are you playing? You might just need a CODEC update. http://codecguide.com/download_k-lite_codec_pack_full.htm Link to comment Share on other sites More sharing options...
caprireds Posted February 14, 2019 Author Share Posted February 14, 2019 thank you all for your replies problem solved ... I wiggled the AUX cable a bit ,and it worked ...that easy !! great forum here.. DentedAphid7 1 Share Link to comment Share on other sites More sharing options...
