zhc45 Posted May 6, 2020 Share Posted May 6, 2020 (edited) It's a problem that I had before and it was solved automatically But this time I seem to have no luck So, when I turn on my pc (i have two fans connected on M/B) one starts to light up and spins for a sec and then stops and the other fan just runs fine Then my gpu which has two fans and those also lights all the time but doesn't spin after spinning for a sec at first The main problem is there's no display on my monitor I've uninstalled everything but the CPU and put those back on but the same thing happens Rig: H81 ds2v i5 4460 Galax Rtx 2060 super And Tt smart 630 psu I was supposed to upgrade once the new 4000 series comes out that's why got the gpu first (just to be not funny😕) Now what am I supposed to do Thanks for any help you put here Link to comment Share on other sites More sharing options...
Mindovermaster Moderator Posted May 6, 2020 Moderator Share Posted May 6, 2020 GPU fanbs are meant to turn off, they only stay on when under heavy load. But as for your motherboard fans, could be a million things. Are you sure your cables are pluggged into the graphic card, not your motherboard? (It happens) Does your mnotherboard have onboard video? Can you take out the graphic card, and try onboard? It could be your memory that is bad. I don't think you ever said how much RAM you had, but try with only 1 stick in. See if it improves any. zhc45 1 Share Link to comment Share on other sites More sharing options...
zhc45 Posted May 6, 2020 Author Share Posted May 6, 2020 Tried with one stick and It runs I dunno what was it But it's fine now Thanks Link to comment Share on other sites More sharing options...
Register a new accountSign in
