OK, I have two routines, Morning, triggered when I say Good Morning, it turns on the lights in my room and tells me the weather. The other simply turns off the lights. What I want to do is have the morning routine turn off the lights after a certain amount of time, i.e. 30 minutes. Is this possible to do? If so, can you provide me the steps necessary? Thanks!
https://www.neowin.net/forum/topic/1435212-help-me-create-an-alexa-routine/
I have something similar in turning my porch light on, so I can leave in the morning, and then turning it off after 15 minutes.
Go into your "Good Morning" routine, and set an action to WAIT for 30 minutes, then set the event to turn the lights off.  This should help you.
  • Like 1
  • Thanks 1
Expand
Thanks! I missed that action!
Register a new account
Sign in
