Changing the Build number in winver.
I read a while ago somewhere that you can change the build number displayed in 'winver' from build 2600.xpclient.... to just Build 2600. I found the line in the registry and changed it, it worked great, but it seems to change back to the original soon after. Is there something else i need to do?
Cheers
https://www.neowin.net/forum/topic/1730-changing-the-build-number-in-winver/
Cheers
Yep you sure can! :) you have to edit the registry, this is how it is done:
HKEY_LOCAL_MACHINE
SoftwareMicrosoftWindowsNTCurrentVersion
Right-Click and modify
BuildLab="2600" <--- or whatever you want to put here.
Originally posted by configure
Err/?? see the attachment.. it's weird..
Yeah that is normal for everyone. I see what you are saying though, "2002" hasn't arrived yet...
But it has always been like that in the beta builds.
Go to the run box and type "winver"
Yeah i can change it, and it works (I assume the FINAL of XP will just say 2600 you see, and i want to make it look neater while im using it.) but after a short while if you look again its changed back (what checks the reg and does that? hmmm).
I remember a while ago someone saying they had done it and showing screenshots (but i cant for the life of me remember where).
Anyway thanks for the help. :D
Good one.. what's the big deal anyways... who cares.. as long as it works. And to that kid that said when the final come out.... hello.. you do have the final. There's no more after this. The Retail version would prolly just tidy up the look of it but it's exactly the same as the one you're using now.. since we are all "beta testers" we've already gained access to XP and all that's left now is just updates..
    • I always disable animations in Windows using sysdm.cpl and yes, it feels faster. I have also reduced animations in my android phone using dev options.
    • Neowin's servers (hosted in the UK).
    • MacOS isn't Linux, but Proton is modified WINE, and WINE runs on MacOS. They would just need to add something like Box86 or Rosetta support.
    • PicPick 7.4.0 by Razvan Serea PicPick is user friendly and full of features for creating your image, suitable for software developers, graphic designers and the home user. It is an all-in-one program that provides a full-featured screen capture tool, intuitive image editor, color picker, color palette, pixel ruler, protractor, crosshair and even whiteboard. It not only has everything that you need, but it loads fast, and sits quietly in the system tray until needed. This software is provided as freeware for personal use only. In this case, you are granted the right to use this program free of charge. Otherwise, you need to pay for a license for commercial use. PicPick key features: For All Windows (Fully support Windows 11, 10, 8.1, 8, 7, Vista and XP both 32-bit and 64-bit) Multi-language is supported. (MORE 28+) All functions are fully supported on a dual screen environment. No Registry, No access to System folder (you can copy these files to portable USB) Screen Capture Auto-scroll, dual monitors and sound effect are supported Various output to File, Printer, Office programs, External program Sharing to FTP, Web, E-mail, Facebook and Twitter are supported as well Full Screen Active Window Window Control Scrolling Window Region, Fixed Region FreeHand Repeat Last Capture Image Editor Intuitive User Interface Windows Ribbon style Standard drawing, shapes, arrows, lines, text, and etc. Blur, sharpen, hue, contrast, brightness, pixelate, rotate, flip, frame effect and etc. Color Picker and Color Palette various color code type (RGB, HTML, C++, Delphi) Photoshop style RGB/HSV conversion is supported. Pick and Save your favorite color! Screen Pixel Ruler Horizontal and vertical orientation various units (Pixels, Inches, Centimeters) DPI setting (72, 96, 120, 300) colorful gradient skins You don't have to install any other screen ruler softwares. Screen Magnifier Zoom 2x to 10x option Stay on top, smooth display, and sizeable window Screen Protractor Have you seen any screen protractor function in other software? Screen Crosshair For aligning objects in graphics or design applications For calculating relative coordinates on screen Some prefer to use this tool than a pixel-ruler. Whiteboard For giving a presentation or just drawing something on screen PicPick 7.4.0 changelog: Added support for saving in WebP file format Added horizontal scrolling in the Image Editor with Shift and mouse wheel Fixed control capture failing to detect specific windows Fixed focus loss during delayed active-window captures. Download: PicPick 7.4.0 | 74.9 MB (Free for personal use only) Download: Portable PicPick 7.4.0 | 73.3 MB View: PicPick Home page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Stellarium 25.2 by Razvan Serea Stellarium is a free open source planetarium for your computer. It shows a realistic sky in 3D, just like what you see with the naked eye, binoculars or a telescope. It is being used in planetarium projectors. Just set your coordinates and go. Stellarium key features: Realistic simulation of the sky, sunrise and sunset Default catalogue of over 600,000 stars Downloadable additional catalogues for up to 210 million stars Catalog data for all New General Catalogue (NGC) objects Images of almost all Messier objects and the Milky Way Artistic illustrations for all 88 modern constellations More than a dozen different cultures with their constellations Solar and lunar eclipse simulation Photorealistic landscapes (more are available on the website) Scripting support with ECMAScript (a few demo scripts are included) Extendable with plug-ins: 8 plug-ins installed by default, including: artificial satellites plug-in (updated from an on-line TLE database) ocular simulation plug-in (shows how objects look like in a given ocular) Solar System editor plug-in (imports comet and asteroid data from the MPC) telescope control plug-in (Meade LX200 and Celestron NexStar compatible) The major changes of this version: Many changes in support of sky cultures Added 2 new plugins: Mosaic Camera and Custom Nebula Textures Many improvements in Core Updates in sky cultures (include new one) [full release notes] Download: Stellarium 25.2 (64-bit) | 361.0 MB (Open Source) View: Stellarium Home Page | Other Operating Systems | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      viraltui earned a badge
      serfegyed earned a badge
      firey earned a badge
      fettermanj earned a badge
      146
      143
