Converting NTFS to EXT without losing data
Hey, Linux users. After a few months of dualbooting XP with Ubuntu, I'm ready to become a 100% Linux user. Unfortunately, my 120 GB D drive is currently formatted to NTFS and is almost full. Is there a way to convert NTFS to EXT without losing everything I have? I want to be able to write to that drive under Ubuntu once I get some of the junk cleared off it.
Note: I know Linux can write to FAT but I've always been under the impression that Linux can write more effectively to its own native filesystem than a predominantly Windows-used filesystem.
since your drive isnt completely full, why dont you just resize your partition and make the unused space into ext3, then move soem files from ntfs to ext3 and then convert the newly freed up ntfs space into part of your ext3 partition, doing it chunk by chunk.. might take a while but you wouldnt lose anything...that would work right?
  rezza said:
You can't convert a live filesystem containing data from one type to another like that
586074602[/snapback]
Dude yes you can.. MS allows you to convert fat to ntfs using the convert command..
C:\>convert /?
Converts FAT volumes to NTFS.
CONVERT volume /FS:NTFS [/V] [/CvtArea:filename] [/NoSecurity] [/X]
As for linux - Here is a howto for gentoo on how to convert these file systems;
http://gentoo-wiki.com/HOWTO_Convert_Filesystems
his will work for these filesystems:
* minix
* xfs
* jfs
* reiserfs
* ext2
* ext3
But off the top - I do not know of an easy, safe way to convert from ntfs to ext2 or 3, or to any other native linux FS... Hmm, I'll take a look around.
586074623[/snapback]
That was a great idea, but for some reason, PartitionMagic isn't letting me create a new partition on my D drive.
586074314[/snapback]
First, congratulations on making the 100% switch. (Y)
It took me quite a while longer than two months to finally ditch Windows completely.
As for the drive issue, do you have a home network going on, and could offload files to another PC? But that is an awful lot of files to move! :blink:
EDIT: If you can remove your Windows system from there, it will free up some room to start using. Not a very efficient option, as you really need to find about a 120GB drive to transfer your data to.
go buy a drive, use it for backup. Kill the partition and make a new one on your old HD, then drop the files back over... After that, return the New HD to where you bought it from... I kno its not the most ethical thing to do, but it does work...
I just cant see how anyone could use nothing but Linux :-( Lack of games just kills it for me...
Thanks a lot. I appreciate it. :)
Unfortunately, my PC is the only one in the house, so my options are limited at the moment. :(
My GameCube and PS2 satisfy my gaming needs.
  gwon said:
The only thing I'm left with now, is the thought of a friend with a spare harddrive? Or a DVD-RW drive and a crap load of disks..
586074887[/snapback]
I have a DVD burner, but not enough DVD-R's for the job, and I'm currently without the 13 bucks needed for a stack of 25 until my next paycheck.
Hmmmm, I wonder. Since I can't get DVD-R's just yet, while at the same time I don't really want to wait that long to get rid of Windows, can I convert the NTFS drive to FAT32, clean install Ubuntu on my C drive, and use a Linux CD/DVD burning application to get the files off the D drive once I buy some more DVD-R's?
Converting from ms filesystem to another ms filesystem doesn't count :p
    * minix
    * xfs
    * jfs
    * reiserfs
    * ext2
    * ext3
Well slap me silly and call me a pickled trout, I never did know about convertfs. Thanks for pointing it out, looks like a nifty tool.
586074640[/snapback]
Indeed, FS converters seem to only convert between filesystems of the same OS, unfortunately.
Maybe this tid bit of advice might help ya out....
Even though we had a 120 on this system, which has now been upgraded, I tend to do cleanup of files and saved programs by priority. Priority being, how hard was it to get those files/programs...how old are they, how many multiple versions have I kept...and how long does it take to re-download any given file, or program???
You may find that you can simply live without any of the backed up programs cuz you'll have plenty of time to redownload them after you've made your final switch. This in turn will free up how many DVDs you'll need to keep the stuff you cannot redownload such as game save files, or photos...pics you've created...songs, rare songs for that matter...or files you got from someone's FTP server that is no longer up. In my case of having only a mere 30gigs used, only about 7.5g's of it is irreplacable, and is backed up to DVD on a regular basis. All the other stuff is just programs used to do fresh installations over the network.
Hopefully, after doing that, you'll have saved some time and were able to burn what was left...giving you the opportunity to clear the entire drive...remove all the partitions..zero the drive, and start with a fresh installation of Ubuntu.
586075128[/snapback]
Sadly, a lot of it is valuable, but I might have enough DVD-R's to burn off what I absolutely CANNOT replace. Thanks for the input.  :)
586075075[/snapback]
Dude it was in answer to your "blanket" statement of;
"You can't convert a live filesystem containing data from one type to another like that"
Which obviously was wrong - in both windows and linux ;)
On another note - how much space do you have available? Would surely be a drawn out process.. But you have some space to work with.. You could copy some files from the ntfs to linux ext2,3,xfs,reiser,whatever.. Then resize the ntfs partition with partition magic or other tools.. Create a linux friendly partition on the freed up space.. move more files from the ntfs partition to the linux parition, resize the ntfs smaller, make the linux one bigger...
Repeat until all files have been moved from the ntfs partition to linux partition - resizing as you go along ;)
Depending on how much space you have to work with - might only take a few iterations ;)
586076708[/snapback]
If you do this, do not use an ext2/3 partition as you linux one. Use reiserfs. Ext2/3 has a fixed number of indoes allocated when the filesystem is created whereas reiserfs creates inodes in it's b-tree as needed. If you use ext2/3, you won't be able to increase the available number of inodes as you increase the filesystem size and hence, you won't be able to make many files.
    • Display Driver Uninstaller (DDU) 18.1.2.3 by Razvan Serea Display Driver Uninstaller (DDU) is a utility for completely removing AMD/NVIDIA/INTEL graphics drivers and related packages from your system, attempting to eliminate all leftovers (including registry entries, folders and files, driver store). Though AMD/NVIDIA/INTEL drivers can usually be removed via the Windows Control Panel, this uninstaller tool was created for situations where standard uninstall fails, or when you need to fully remove NVIDIA or ATI graphics card drivers. After using this driver cleaner, your system will behave as though it’s the first time you’re installing a new driver—similar to a fresh Windows installation. As with all such tools, we recommend creating a restore point beforehand, allowing you to undo changes if issues arise. If you're having trouble installing an older or newer driver, try it—there are reports that it resolves such problems. Recommended usage: The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best. Make a backup or a system restore (but it should normally be pretty safe). It is best to exclude the DDU folder completely from any security software to avoid issues. You do NOT need to uninstall the driver prior using DDU. Requirements: .NET Framework 4.8 Compatible with Windows 7, 8, 8.1, 10, and 11 (32-bit or 64-bit) Note: Using on Insider Preview builds is at your own risk. Display Driver Uninstaller (DDU) 18.1.2.3 changelog: All GPUs: Fixed hardware rescan issue when cleaning all GPUs without restarting or shutting down UI: Added Guru3D mention in the About section. General: Various fixes and enhancements. Download: Display Driver Uninstaller (DDU) 18.1.2.3 | 1.7 MB (Freeware) Download: DDU Portable | 1.2 MB Links: Display Driver Uninstaller Home Page | Screenshot | Forum Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • That would be nice, if excel could refresh pivot tables without bugs. Frequently you refresh a pivot and all parameters get lost. Now this will happen automatically. Bravo MS!
    • If one could ever put all the crap of the world in one box, that would be Microsoft.
      Homayoun Hotak earned a badge
      Profit earned a badge
      hhgygy earned a badge
      NIKI77 earned a badge
      168
      123
