My first Mac....need some help.
Ok, I got my firts Mac last night, an iBook combo drive. I have never used OS X before so I need some help on some basics. So let me pick your brains:
- How do you change application and drive icons? I know how to change folders.
-How do I apply themes? Does it install automatically after I download it?
-How do you change the dock background?
-Is there a hacked MSN Messenger with out ads?
-Do you have a working link for the chimera theme for Mozilla? The one I have does not work.
-After 24 hours, I would have to say OS X is very smooth and easy, and damn it is beautiful.:D
Any and all help is appreciated.:)
https://www.neowin.net/forum/topic/37402-my-first-macneed-some-help/
Drive icons are changed the same as regular icons, just copy and paste from the info dialog like folders.
Themes, you need duality ~ here
Custom dock PDF's can be applied with Transparent dock
MSN 3 withough ads requires office X to be installed.
Navzilla theme here: http://www.zukes.com/mozilla/navzilla/
You can always give Chimera a try, it's pretty cool and approaching 0.4
Wow, those Apple switch propaganda must be really effective.
GatorZx2 will be the next Apple satisfied customer to be on T.V. telling us to make the change ;) :p OS X looks nice, I play with it at the Apple store in the mall, but I'm not going to buy a Mac. I'm comfortable with my Windows OS.
Originally posted by cerbero
You lucky sob.. :)
I'm most probably gonna buy mine in August though, so I'm not far behind. Haven't decided wether I should get a used PowerMac or a new eMac yet though.. Depends on what ads are out at the time I guess..
Well, good luck with your new stylish machine :)
go with the used powermac because its going to be loads easier upgrading it than upgrading the emac
Just got my first mac today (eMac) and I have most things figured out. I have to say though that the people in the switcher ads NEVER had to install software on OSX. . hehehe I finally figured out how to get the box to enter the admin password. Anyway, does anyone know if it's possible to bring up IE's download manager without first downloading something? Anyone have any must-have freeware OSX apps to have?
BTW-I took me all of 5 minutes to ditch the pro mouse in favor my MS Intellieye :cheeky:
Originally posted by Airw0lf
if its your first mac then buy the emac.
if u need experience with mac-feeling then u'll go best with the emac!
it's fast, half cheaper than the powermac :D, and most comfortable in os x.
I said I'm getting it used. Less money than an eMac, and more power. No hard choice :) Plus I already have a kickass CRT monitor (even though it's 2 years old).
Oooo, another new mac user. Well, there's all the stuff mentioned above that Gator asked. As for must have freeware apps, I currently use
Acqusition
Limewire
neo
Transparent dock
Transmit
snak
You can grab all of those from Versiontracker.
And you have got the MS Intellimouse software haven't you?
Acqusition
Limewire
neo
Transparent dock
Transmit
snak
Thanks Dazzla. And yes I fetched the Intellimouse software. I know what Transparent dock and Limewire are. The rest I will look up on the site you mentioned. How bout a freeware app to view/convert graphics formats? I find it odd that OSX doesn't ship with some kind of paint app considering the perception of Macs being for "creative" people. Thanks again.
I've only just recently noticed this, but if you open up a graphic file in Preview, you will have to option to Export (File - Export...), here you have the option of exporting to:
SGI
Photoshop
BMP
Jpeg
Pict
PNG
Macpaint
Tiff
TGA
JP2
Quicktime Image
See:
You've also got control over quality etc of the image:
Originally posted by creamhackered
I want to buy an iBook
what one is the best and are they any good/easy to use?
I need a notebook and I dont really like Windows based notebooks and I want a mac system in my house :)
The 700/12"/Combo Drive is the best iBook in my opinion and many others around. There is the 14" for $300 more that people say just doesn't look right and is kinda bulky and flimsy. Go compare the two at a store and you'll see what I mean. The 12" and the 14" use the same resolution so the 12" has a a sharper screen. You may think the 12" is too small but I've had mine for a week and its a perfect size and when I do detailed design work I just plug in my 17" monitor.
Sweet thanks I will consider that :)
SGI
Photoshop
BMP
Jpeg
Pict
PNG
Macpaint
Tiff
TGA
JP2
Quicktime Image
See:
Ahhhh I saw that in the apps folder but wasn't sure what it was. I have to say that after playing with my new toy all of yesterday evening. . . I LIKE I LIKE. I noticed first off that when I was using 10.1.4, I would start to get a headache after an hour because of slightly blurry fonts (AA?). After updating to 10.1.5 it doesn't seem as bad. Hmmm. I must say that although I don't have another mac to compare it to, this eMac is quite zippy. Will reask the question about whether or not it's possible to bring up IE's download manager without actually having to download something?
Click "window" then "download manager" or command 4. I wouldn't use IE full time. I think you would find Mozilla, Chimera, or OmniWeb faster and more accomidating.
    • Anker announces global recall of five power bank models over fire safety risks by Aditya Tiwari The Chinese electronics brand, Anker Innovations, known for its mobile accessories and power banks has announced a voluntary global recall of five power bank models. The decision comes after the company spotted a potential fire hazard issue with lithium-ion battery cells from a particular vendor. Anker said that it put up a series of quality checks to detect manufacturing issues early in the production cycle, which include component level-audits and supplier testing. The company assured that "while the likelihood of malfunction is considered minimal, out of an abundance of caution, we have decided to initiate a voluntary global recall of several Anker power bank models." Here's the list of the Anker Power Bank models chosen for the global recall: Model A1257 - Anker Power Bank (10K, 22.5W) Model A1647 - Anker Power Bank (20,000mAh, 22.5W, Built-In USB-C Cable) Model A1652 - Anker MagGo Power Bank (10,000mAh, 7.5W) Model A1681 - Anker Zolo Power Bank (20K, 30W, Built-In USB-C and Lightning Cable) Model A1689 - Anker Zolo Power Bank (20K, 30W, Built-In USB-C Cable) If you think you own one of the affected power banks, you can check the model number located on the back or side of your power bank. After that, you can fill out the recall form to start the process and verify the serial number of your affected device. If your power bank is eligible for the recall, you can either get a replacement or receive a gift card for use on the Anker website. It's not offering any refunds in the US at the moment. Anker advises that you should stop using an impacted power bank immediately even if the device functions normally right now. A unit confirmed for the recall could pose the risk of overheating, melting, smoke, or fire. This is the second major recall from Anker in the same month after more than a dozen reports of fires and explosions. The company previously recalled over one million Anker PowerCore 10000 (A1263) power bank units, citing fire safety risks due to a potential issue with the Lithium-ion battery. These power banks were sold in the US from January 1, 2016 through December 31, 2022.
    • What learning curve !!?? Govt office employees never learn anything !! they're just there to not work !!
    • "The entire scanning and conversion process takes place locally on your device, using Android’s built-in API for snapping documents. The document itself is also only stored locally until you decide to send it. Just like other WhatsApp messages, these scans are secured with end-to-end encryption when you send them to recipients. The only privacy risk is the user sending the PDF to the wrong person."
    • It is a great product though... in this case, I don't mind paying.
    • Collaborator
      Mighty Pen went up a rank
      Collaborator
      emptyother earned a badge
      DarkWun earned a badge
    • Very Popular
      valkyr09 earned a badge
      Very Popular
      suprememobiles earned a badge
      189
      Skyfrog
      112
      110
