Hi,when i try to boot from the dvd i get instantly the error BlInitializeLibrary failed 0xc0000017. on another computer it went fine, so the dvd is not corrupt.
i changed every component of my computer except the mainboard, the cpu and the memory.
i tried an old dvd drive, an old ide hdd, an old pci graphics card, removed the sound card, removed and changed the ram modules... but no change, i could not boot the dvd. i also tried installing from winxp, but when it comes to reboot the same error occures as with the dvd.
Windows XPpro SP2 runs fine with all these components. I dont have any clue what causes this problem. i reset all bios options, tried to set some (like cool n quiet etc)....
my system:
Asus A8N32-SLI
Corsair TWINX2048 3500LL PRO
XFX GeForce7800GTX Extreme XXX
SoundBlaster X-Fi Elite pro
Plextor PX716SA (SATA DVD Burner)
2x Western Digital WD740GD Raptor 74GB SATA hard drives -> raid0
i can't setup my vista 5259 too.
but I have another type of problem.
i don't wanna to create another thread, so i'll post it here:
so, setup starts... i entering serial, then some files copied to my hard drive, > restart > and when the longhorn logo shows my pc is going to reboot. :unsure: no error or other codes :wacko:
  petroid said:
The only time I've encountered this is on older hardware that doesn't meat the Vista spec anyway, such as a P3 800 with 128MB ram.
my scpecs is
EPoX EP-8RDA3+ on nForce2 Ultra400
barton3200+
512 ram
sapphire 9600 xt 128 mb
:unsure:
looks like not so old :p
  • 3 weeks later...
  Tyke said:
I am getting the same problem as this with the 5720 Build. I have the same motherboard A8N32-SLi, and a single Raptor drive, so I guess the MB is causing the problems.
Tyke
Same thing here. I looked in the Asus forums, but no luck. This is killing me, because I really want to try this build out. :no:
Thought I was going to be slick, and run it from Windows on my other partition. Then as soon as it rebooted BAM. Had to run fix boot on my XP partition just to get back into Windows.
  • 3 weeks later...
Try writing the image to a different DVD disk, if you used -r use +r. I have documented the bug with MS and have been able to re-produce it.
I have seen this on several systems, and others have try this and it seems to fix the issue in most cases.
  • 1 month later...
my system:
Asus A8N32-SLI
Well, I have nearly the same hardware configuration and have the same problem with
the "BlInitializeLibrary failed 0xc0000017" message at the boot time.
Here's my hardware
Asus A8N32-SLI Deluxe (nForce-4 chipset)
Athlon 64 (Venice) 3200+ (2.00 GHz)
2GB main memory DDR400 ECC Kingston KVR400x72C3A/1G (2 DIMMs)
GeForce 6200 PCI-exp16 MSI NX6200TC-TD64ESLF
320GB SATA disk WD3200JD
DVD+/- Double Layer IDE NEC ND-3550A
This new computer has been successfully installed with Win XP-Pro.
I failed to install Win98SE. At the first reboot after installation from CD,
Win98SE crashes at the beginning no matter what (with some device driver
executing an illegal opcode). That's a surprise. But, my real problem is with
the new Longhorn installation.
Somewhat similar to my experience with Win98SE (the initial reboot fails),
the Longhorn installation went fine and at the first re-boot, the screen shows
"BlInitializeLibrary failed 0xc0000017" and hangs. I'm using the Beta 1
version (build 5112).
I don't believe this is related to DVD. This message is generated by
the boot sequence from the hard disk that apparently does not have the
right device driver or something on the hard disk. It is believed that
the nForce4-based motherboard is not well tested/supported by Microsoft
for the Longhorn (Vista) environment.
The same Vista beta version runs well on my 4-year old system
with Asus P4T-E MB with Pentium 4 1.9 GHz (512 MB RDRAM).
It seems that the Longhorn does not come with all the necessary drivers
for this motherboard. The next step that I plan to take is to contact
Asus who may know somethingi about this problem.
Kan
