neo1980 Posted November 19, 2001 Share Posted November 19, 2001 whenever i play a game the screen settings change, whenever i reboot the screen settings change..they go in the extreme right hand corner and a bit to the top and i have to adjust it all over again!!! please help! Link to comment Share on other sites More sharing options...
EmuZombie Veteran Posted November 19, 2001 Veteran Share Posted November 19, 2001 what is "they"? Link to comment Share on other sites More sharing options...
neo1980 Posted November 19, 2001 Author Share Posted November 19, 2001 they = settings of the screen...i have the adjust the length width again of the screen cuz it goes to the left top ahnd side corner..help! Link to comment Share on other sites More sharing options...
neo1980 Posted November 19, 2001 Author Share Posted November 19, 2001 helo :( Link to comment Share on other sites More sharing options...
EmuZombie Veteran Posted November 19, 2001 Veteran Share Posted November 19, 2001 well, it sounds to me like a driver problem... Do you have beta drivers installed for your video card or monitor? If so, try using non beta. If not, see if the drivers are up to date. Link to comment Share on other sites More sharing options...
neo1980 Posted November 20, 2001 Author Share Posted November 20, 2001 but when i restart my computer, the screen where it tells the Logo of Emachines, even that becomes automatically distorted in some way, the drivers dont apply there Link to comment Share on other sites More sharing options...
IceHawk Posted November 20, 2001 Share Posted November 20, 2001 E-MACHINE?! Link to comment Share on other sites More sharing options...
