- 0
C++ Help Coding Problem
Asked by
dana120864,
Recently Browsing 0 members
Posts
By sphbecker · Posted
I'd say the first one failed to be as popular as Apple anticipated, but the easy adjustment here is to make fewer of them next time around. It would only be a "flop" if it isn't possible for Apple to recover the design and factory tooling costs given the number of units sold, which I doubt would be the case. It isn't like no one bought them; it just failed to become the new hot phone of the year. -
You're right that it does not follow the plain meaning of the word, but in this context, it is a legal term defined in 49 U.S.C. Kind of how "wire fraud" laws apply even if a physical wire was not used. Given that it is codified in law, and it isn't just automotive journalists that don't understand evolving technology, I highly doubt congress would change a well understood term just because technology makes the term slightly less actuate. -
By PsYcHoKiLLa · Posted
"OuT Of My WaYmO !" -
This is exactly why I keep saying we are not ready for human free self-driving. These little "bugs" are may seem like random one-offs. There was also the Waymo that drove between police with drawn weapons and the suspect they were pointing them at. From a software perspective it is easy to understand how those extremely rare situations may not have been programed for, but that is the point. If AI needs to be told to watch out for every possible contingency, then it can never be successful. There will always be the possibility of a first encounter that the AI needs to understand to avoid. -
By Copernic · Posted
TeraCopy 4.0 Final by Razvan Serea TeraCopy is a compact program designed to copy and move files at the maximum possible speed, also providing you with a lot of features. Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce seek times. Asynchronous copy speeds up file transfer between two physical hard drives. Pause and resume transfers. Pause copy process at any time to free up system resources and continue with a single click. Error recovery. In case of copy error, TeraCopy will try several times and in the worse case just skips the file, not terminating the entire transfer. Interactive file list. TeraCopy shows failed file transfers and lets you fix the problem and recopy only problem files. Shell integration. TeraCopy can completely replace Explorer copy and move functions, allowing you work with files as usual. TeraCopy is free for non-commercial use only. For commercial use you need to buy a license. The paid version of the program includes the following features: Copy/move to your favorite folders. Save reports as HTML and CSV files. Select files with the same extension/folder. Remove the selected files from the copy queue. Download: TeraCopy 4.0 | 14.6MB (Freeware, paid upgrade available) View: TeraCopy Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
Recent Achievements
Eurosoft10 earned a badge
Skeet Campbell earned a badge
Sharbel earned a badge
BizSAR earned a badge
Popular Contributors
Tell a friend
dana120864
I am using Dev-C++ and my code isn't working. When I compile it it stops at the code C=A. The error message states that I don't have a header and the program doesn't recognize C=A. This is the question and I will give you what code I have.
I do not know what I am doing wrong. Help Please.
Write a program that declares 2 constants A and B, Initialize A=1 and B=2.2, Declare an int named C and a float named D, Initialize C=A and D=B, Write statements to print C and D to the screen
Ok here is my code:
// abcddec.cpp
// example of printing C and D
#include <iostream>
#include <cstdlib>
using namespace std;
int main()
int C;
C=A;
A=1;
float D;
D=B;
B=2.2;
cout << "C\n";
cout << "D\n";
system ("PAUSE")
return 0;
https://www.neowin.net/forum/topic/660056-c-help-coding-problem/Share on other sites
31 answers to this question
