Lost Planet EC DirectX 10.0 Resolution problem
I'm having an issue when trying to run Lost Planet Extreme Condition in DirectX 10.0 mode. I can't change the resolution any higher than 640x480 for some reason.
I'm on Windows 7 x64 and have a Nvidia Geforce 9800GT. I am using the 195.39 64-bit forceware drivers from Nvidia.
Apparently Lost Planet actually requires you to add the missing DX files, in both 9.0 & 10, in both XP and Vista, and I'd assume the same for 7.
Lost Planet PC got horrible reviews because it was a direct port of the 360 version, and they didn't bother encoding it right.
As such, it's very, very, very, very buggy.
More info please. Does it stall if you go higher? Or does it not even let you choose a higher resolution?
You could try setting is manually in the config file if it's got one. Try a different driver revision.
I take it that you can go over 640x480 in dx9?
edit: haha Minifigs post wasn't there when I wrote this. That's so pathetic of the devs although youd think without the dx files there would just be an error on startup I think this may be another problem. Incase you didn't realize, you won't miss anything from playing in dx9 anyway.
Edited by stunts
It won't let me go any higher as in there is only two resolution options to choose from, with 640x480 being the highest. In DX9 mode I am able to choose a higher resolution. The problem seems specific only to DX10 mode and I am unsure of what I can do to fix the problem.
Honestly don't do anything just play in dx9 I know it may be nice to play in dx10 just for the sake of utilizing your hardware but there's really no point in this game. Theres an ATi hotfix for older driver version for the dx10 mode in this game which may do it, anyway if you google it you'll find lots of people have this problem.
I don't really mind playing in DX9, but I don't like my options to be limited either. I'm more interested in fixing the problem than playing in DX10 mode itself, that's not saying I won't play in DX10 mode if given the option to as I want to get the most out of my hardware so long as it doesn't drastically affect performance. :)
The performance hit of DX10 isn't worth the slight or perhaps negligible image quality improvements. I've seen benchmarks where the FPS is nearly halved from DX9 mode to DX10 mode.
i bought the game for $5 on Steam a while back. are you playing on Steam or standalone?
i have no issues w/ DX10 on Vista x64 a while back. Today im using 7 x64, so i havent tried the game since i beat it. if i remember, i'll try after work today...
@Minifig - i didnt notice any bugs at all when i played. yeah, the controls were a little wonky b/c of the porting aspect, but no bugs.
UPDATE - i just tried playing through Steam and everything was fine... sorry Xtreme
Edited by Jdawg683
    • So, do nothing basically, as long as you deploy Windows Updates? Pretty much yeah. Some Linux distros distribute update the secureboot certs as well, assuming you do use SecureBoot.
    • On one hand, YouTube videos are filled with so much fillers and the Youtubers intentionally speak slowly to increase video time and "engagement" metrics. On the other, Google's asking you to not stay on their site for longer. That's a win-win for viewers. So, I think it'll be axed or de-emphasised in the near future.
    • They'll just repurpose that for their AI trainings. Its never enough for LLMs.
    • Ubuntu gets second-ever snapshot release for Questing Quokka by Paul Hill Canonical has announced the release of Ubuntu 25.10 Questing Quokka Snapshot 2, a monthly development build that gives testers and developers a base from which to work on software for the upcoming release. Snapshot 1 was released at the end of May and Snapshot 3 is scheduled for July 31. Notably, the release date of Snapshot 2 and 3 have moved since last month. The Snapshot 2 update is available for various Ubuntu spins, such as Kubuntu and Lubuntu. To download, head to Ubuntu CD Image and go to the link for the version you want, such as ubuntu/. Once you’ve picked, go to releases/ > 25.10/ > snapshot-2/ and download the appropriate image for your computer - most people will want ‘64-bit PC (AMD64) desktop image’. The announcement mentions that these snapshot builds are not production ready, so you should not be installing them on a machine you use to do your work and daily computing. Canonical said that these builds should be seen as “throwaway artifacts”, whatever that means. If you’re an Ubuntu developer, you should submit your changes in the Ubuntu archive by July 28 to see it in the third snapshot. If you make any changes, Canonical asks you to update the Release Notes with the updates that you have worked on, so everyone knows what changed. Speaking of release notes, Canonical has been updating them incrementally. So far, we know that GNOME 48 is being used alongside the Linux 6.14 kernel. The use of GNOME 48 means that Ubuntu 25.10 only supports Wayland sessions as X.org has finally been dropped. Wayland has been used for a while on Ubuntu, so most people shouldn't have any issues as a result of the switchover. If you want to try out Ubuntu 25.10 Snapshot 2, you can find the download links over on the Ubuntu website. Just remember, these are not intended to be used on production machines!
      Marites earned a badge
      runge100 earned a badge
      jfam earned a badge
      TheRingmaster earned a badge
      177
      118
