I recently got access to the Status Audio Pro X wireless earbuds, a recent entrant in the premium wireless earbuds market. At $299, the Status Audio Pro X sits in the same premium market as Apple and Sony. That price sets high expectations. These earbuds focus more on sound quality than the smart AI features commonly found on other premium wireless earbuds, and in many key areas, they deliver well.
Disclaimer: Status Audio provided the review unit without any review inputs or pre-approvals.
| Status Pro X | |
| Model: | Pro X |
| Driver: | Hybrid Triple Driver: 12 mm Dynamic + 2x Balanced Armature (Knowles) |
| Audio Technology: | LDAC (Hi-Res Wireless), AAC, SBC, LC3 (Auracast Ready) |
| ANC | -52dB Hybrid Active Noise Cancellation |
| Frequency Response: | 20 Hz - 40 kHz (Hi-Res Wireless Certified) |
| Sample Rate: | 96 kHz / 24-bit (via LDAC) |
| Impedance Range: | Not specified |
| Bluetooth Version: | 5.3 (LE Audio Support) |
| Bluetooth Profile: | HFP / A2DP / AVRCP / BLE / SPP |
| Transmission Range: | >10 m / Bitrate: up to 990 kbps |
| Maximum Transmit Power: | Not Specified |
| Wireless Freq Band: | 2402 MHz-2480 MHz |
| Battery: | Li-ion Polymer (Case capacity not specified; approx. 24h total backup) |
| Charging Port: | USB-C & Qi Wireless Charging |
| Input Power: | 5 V ⎓ (Standard USB-C) |
| Charging Time: | ≈ 1.5 - 2 h (Earbuds) |
| Playing Time: | ≈ 8 h (ANC OFF) / ≈ 5 - 5.5 h (ANC ON) |
| Weight: | 5 g (Per Earbud) / 48 g (Case) / ~58 g (Total) |
| MSRP: | $299.99 |
What's in the box
Status keeps the unboxing experience minimal and functional. The box uses simple paper/cardboard compartments for the accessories, so it doesn’t feel “luxury,” but it does the job and keeps everything secure. Here's what you will get in the box:
2x Pro X Earbuds (Left & Right)
Charging Case
Silicone Eartips (S X2, L x 2)
Charging Cable (USB-C)
User Guide
Design and Fit
The industrial design of the Pro X is clean and simple. They look unique in a sea of AirPods knockoffs. The earbuds are compact and fit securely in my ears. I was able to use them for long listening sessions without much discomfort. They include both a capacitive touch surface and a physical button for easy control.
The Pro X offers both capacitive touch controls and a physical button. I used touch controls for the everyday actions like play/pause, next/previous track, volume control, and answering/ending calls. The physical button is useful for actions where you want a more reliable press, like switching between ANC and transparency, or triggering the voice assistant. In my usage, the touch controls worked well, but I still preferred the physical button for noise control because it avoids accidental touches.
The USB-C compatible charging case is also compact and easy to carry. Overall, the build quality feels solid. These also come with IP55 certification, making them resistant to dust and occasional water splashes.
App and Connectivity:
The Status Hub app allows you to control ANC, transparency mode, EQ settings, and touch controls. You can also locate your lost earbuds within the app. These earbuds also have native support for Android Fast Pair and Microsoft Swift Pair. When I opened the earbuds for the first time while I was working on my Windows 11 PC, I was surprised to see the Swift Pair pop-up to connect the earbuds to my PC with a single click.
The Pro X supports multipoint and can stay connected to two devices at the same time (for example, a phone and a laptop). It does not mix audio from both devices. In my usage, switching worked like this: if my laptop was playing music, I had to pause it first, and then press play on my phone to move audio to the phone. Once I got used to this, it was convenient during work calls and media switching.
Sound Quality
Sound quality is the biggest strength of the Status Audio Pro X. The triple-driver setup delivers clear vocals, crisp detail, and strong bass without overpowering the mids. Music sounds balanced and enjoyable across different genres. The Sony WF-1000XM5 sounds better than these with a wider soundstage, but these sound better than the Samsung Galaxy Buds 3 Pro.
When using advanced Bluetooth codecs like LDAC and LC3 on supported Android phones and compatible apps, the sound becomes even better with improved clarity and depth. For normal video watching on YouTube, I did not notice any major lip-sync issues. Audio felt in sync with my usage. But you will notice a small latency delay during fast-paced games.
Active Noise Cancellation (ANC)
The Active Noise Cancellation is good and works well in most common situations, such as reducing traffic noise and general background noise, such as fans. However, it is not at the level of market leaders like the Apple AirPods Pro 3 or Sony WF-1000XM5. Those earbuds still block noise more effectively, especially low-frequency sounds. But ANC on the Pro X is good enough for daily use.
Transparency Mode
The transparency mode works, but it falls behind market leaders like the Apple AirPods Pro 3 and Bose QuietComfort. I was able to hear sounds from the environment, but they sounded artificial. The feature is usable, but not one of the highlights of the Pro X.
Battery Life
Battery life is good but not outstanding. Status claims around 8 hours on a single charge, but with Active Noise Cancellation enabled, I got around 5 to 6 hours. With the charging case, you can comfortably extend the battery life to a whole day.
Call Quality and Microphones
As premium earbuds that cost about $299 and feature three beam-forming microphones on each earbud, I expected top-notch call quality. However, it turned out to be only average. In an ideal environment, my voice sounded clear on the other end. But in noisy surroundings, the microphones struggled to block background noise effectively.
Status claims it uses its Voiceloom AI speech enhancement technology to improve mic performance, but it didn’t meet my high expectations given the hefty price tag. Here’s what the company says on its website about Voiceloom:
By combining beam-forming, robust DNN algorithms, and precise noise reduction techniques, Voiceloom ensures your voice stands out—even in the noisiest settings.
These earbuds are fine for casual calls, but not ideal if call quality is a priority. In my opinion, the Apple AirPods Pro 3 still set the gold standard for call performance. Hopefully, Status can further improve call quality in future firmware updates.
The Status Audio Pro X is a sound-first pair of earbuds. The triple-driver setup delivers clean vocals, good detail, and strong bass without overpowering the mids. With LDAC on supported Android phones, the sound gets even better, and that is the main reason to buy these.
Where it falls behind is in the extra features. ANC is good, but not at the level of Apple or Sony. Transparency mode works, but it sounds a bit artificial. Call quality is fine for casual use, but not what I expected for a $299 product.
At the current $249 price, it is easier to recommend if sound quality is your top priority. But if your priority is ANC, transparency mode, or call quality, Apple and Sony still do a better overall job.
The Status Audio Pro X is now available for $249 ($50 discount), and you can order it from Amazon US from the link below:
0 Comments
