We're never going to see anything come of this like all the other 'alternative fuel' inventions. It seems every couple years or so, someone comes up with this new invention that gives an alternative source of power/fuel, it is then bought up by either an auto maker or the government then never seen again.
Also I imagine this needs distilled water, or at the very least some sort of clean water that does not come from a tap.
Plus you can make your own distilled water at home by boiling the water, then collecting the steam (steam is the distilled water). (Expensive as far as electricity on a large scale) but works in a pinch should say the new HHO station (water station to replace gas) ran out of water. :)
Also Illegal in the USA.. its illegal to own an operate a still...
How do you figure? It is for the purposes of producing an alcoholic beverage, but not if end result is just going to be water. If you think about it, that would mean anyone using a kettle, iron, dishwasher, etc could be arrested and charged.
nah, you still need to produce the electricity for his special electrolysis process, no such thing as free energy :p
but its a nice way of carrying around compact fuel
"Free Energy" what scientists call "dark matter" does exist. You know all the energy released when an a-bomb explodes? That's what they call dark matter. Figuring out a way to harness it safely and use it as an energy source is where it gets tricky. If we could only manage to harness that in a good way instead of using it to destroy :no: It's been known for years that it could be used as an energy source. You're pulling the energy directly from the air...well everything around you actually. You can fart and power a house.
BTW there's been a few people in history to get a car running on only water. Weird thing is that they usually vanished after making it known to the government ;)
Here's another guy to have figured it out. Only this time it's known about publically. But what's the first thing the government wants it for? MILITARY USE :angry: Tell me that isn't BS
But if you own a diesel car just pour some french frie oil in the tank and there's you some fuel
Here's the deal...
Yes, by using electricity you can extract the Hydrogen from water leaving a waste product of oxygen (which as waste products go, isn't too bad).
Hydrogen can then be used to power a fuel cell vehicle like the forthcoming Honda FCX. Fuel cell vehicles also have very clean emissions.
The only problem is that fossil fuels are often used to generate the electricity used to power the process that separates the hydrogen from water.
If you want this to be a real solution (that actually reduces dependence on mid-east oil) then you would need to invest in greener electricity-generating options (solar, wind, hydro, etc...) to power the hypdrogen collection process.
Here's the deal...
That may be true, but at least it's cutting down on emissions from the consumer end. So essentially, it's a step in the right direction until somebody comes up with a way to generate the electricity without the fossil fuels.
Dark matter isn't what's released in nuclear explosions. Dark matter is the yet unknown matter that causes graivty to hold deep space objects together, especially noticeable on a large scale. I.e. what holds galaxies together, as the observed matter is according to theories too small. Therefore, there must be a hypothetical "dark matter" as well.
The energy released when an atomic bomb explodes is rather well documented and understood and has little, if anything, to do with dark matter. It's mostly about thermal radiation and one can read more here.
And no, according to current theroies, free energy exist nowhere, not in dark matter, atomic bombs (these simply release potential energy in the atomic nucleus itself), or anywhere else. Free energy would violate very fundamental physical theories.
That's called nuclear reactors. :p
That's controlled nuclear reactions, as opposed to the uncontrolled ones you're seeing in atomic bombs. Guess why these provide enormous amounts of energy from relatively little raw material. Nuclear reactors split atoms too, just like the bombs, but with humans in control, besides with meltdown disasters. ;)
Edited by Jugalator
    • Last time I used Pascal was in college about 40 yrs ago, programmed an inventory database for my exam.
    • If they don't sell enough of the 1st gen then there won't be a 2nd gen
    • Epic fail, should've added an eSata port on the back, also if the memory/NVME are soldered then they're hardly gonna sell any, first thing most people do with their Steamdeck is, or used to be, replacing the NVME with a 2TB one.
    • GEEKOM kicks off Prime Day Sale with discounts up to 30% on Intel and AMD mini PCs by Steven Parker GEEKOM has kicked off its Prime Day Sale letting you save up to 30% on mini PCs in every price class. Below we are sharing a few highlights from the A series of AMD mini PCs, along with an Intel variant with pretty beefy specs. We start off with the very affordable GEEKOM A5 in the AMD Ryzen 5 7430U, 16GB RAM, and 512GB NVMe SSD configuration, with some of its highlighted specs listed below: Operating System: Windows 11 Pro CPU Model: AMD Ryzen 5 7430U CPU Speed: 3.5 GHz Cache Size: 16 MB Graphics: Integrated AMD Radeon Vega 7 Graphics Memory: 16 GB 3200 MT/s DDR4 Copilot+ PC: No SSD: 512 GB Connectivity: Bluetooth 5.2 + WiFi 6E I never got the chance to review this variant, but here is how GEEKOM describes it: GEEKOM A5 [Ryzen 5 7430U, 16GB+512GB] for $371 —was $439 (15% off) Next up is the GEEKOM A6 in the AMD Ryzen 7 6800H, 16GB DDR5 RAM, with a 1TB PCIe 4.0 NVMe SSD configuration, with the below highlights: Operating System: Windows 11 Pro CPU Model: AMD Ryzen 7 6800H CPU Speed: 4.7 GHz Cache Size: 16 MB Graphics: Integrated AMD Radeon 680M Memory: 16 GB 4800 MT/s DDR5 Copilot+ PC: No SSD: 1 TB Connectivity: Bluetooth 5.2 + WiFi 6E I gave the A6 high marks in my dedicated review from just over a year ago; GEEKOM has this to say about this compact Mini PC: GEEKOM A6 [Ryzen 7 6800H, 16GB+1TB] for $524 —was $649 (19% off) Next up is the MAX variant of A-series mini PCs in the Prime Day Sale. The GEEKOM A7 MAX [2026 Edition] powered by the AMD Ryzen 9 7940HS with 16GB of DDR5 and a 1TB SSD. Below are some of its more important specifications: Operating System: Windows 11 Pro CPU Model: AMD Ryzen 9 7940HS CPU Speed: 5.2 GHz Cache Size: 24 MB Graphics: Integrated AMD Radeon 780M Memory: 16 GB 5600 MT/s DDR5 Copilot+ PC: No SSD: 1 TB Connectivity: Bluetooth 5.2 + WiFi 6E I reviewed this Mini PC a year and a half ago, and praised it for its modern internals like a dedicated NPU and DDR5 memory, as such it is more than capable of keeping up with today's offerings of Mini PC on the market. GEEKOM A7 MAX [Ryzen 9 7940HS, 16GB+1TB] for $594 —was $699 (15% off) Next we have another in the MAX series of A mini PC. The GEEKOM A9 MAX powered by the AMD Ryzen AI HX 470 with 32GB DDR5 and a 2TB SSD. Below are some of its more important specifications: Operating System: Windows 11 Pro CPU Model: AMD Ryzen 9 AI HX 470 CPU Speed: 5.4 GHz Cache Size: 24 MB Graphics: Integrated AMD Radeon 890M NPU: 55 TOPS Copilot+ PC: Yes (combined NPU+CPU=86 TOPS) Memory: 32GB 5600 MT/s DDR5 SSD: 2 TB Connectivity: Bluetooth 5.4 + WiFi 7 We reviewed this Mini PC last month, also in the 64GB configuration. Be sure to check out both reviews before dropping this kind of money on it, you won't be sorry! I praised it for its excellent NPU (AI) performance and premium all-metal build, as such it is more than capable of keeping up with today's offerings of Mini PC on the market. GEEKOM A9 MAX [Ryzen AI 9 470 HX, 32GB+2TB] for $1,444 —was $1,699 (19.72% off) Last but not least we have the GEEKOM IT13 MAX, which is an Intel configuration featuring the Ultra 9 185H with 16GB DDR5 memory and a 1TB SSD. Below are some of its more important specifications: Operating System: Windows 11 Pro CPU Model: Intel Ultra 9 185H (65W TDP) CPU Speed: 5.1 GHz Cache Size: 24 MB Graphics: Integrated Intel ARC Graphics Copilot+ PC: No Memory: 16GB 5600MT/s DDR5 SSD: 1 TB Connectivity: Bluetooth 5.4 + WiFi 7 I never got a chance to review the IT13 MAX, but I did review the GEEKOM X14 Pro which has comparable specifications if you want to get an idea of the IT13 MAX's capabilities. In any case this is what GEEKOM has to say about this variant: GEEKOM IT13 MAX [Intel U9 185H, 16GB+2TB] for $764 —was $899 (15% off) Check out other US and UK deals too These are just a sample of discounts in GEEKOM's Prime Day Sale, you can check out the entire line up, which include more Intel and AMD mini PCs, discounted at up to 30% off, which was more than the recent Spring Sale they ran earlier this year. You can check out the entire lineup of Prime Day deals on the dedicated GEEKOM store page at Amazon in the following regions: Amazon US GEEKOM Prime Day Sales (up to 30% off) Amazon UK GEEKOM Prime Day Sales (up to 30% off) What's more, all products from GEEKOM receive a 3-year free Warranty from the date you receive the product. If needed, you can RMA or return locally relative to your region (the U.S. has a U.S. warehouse, mainland E.U. has a German warehouse, U.K. has a U.K. warehouse, Australia has an AU warehouse). To recap, here are all of the above mentioned deals, available on Amazon US. GEEKOM A5 [Ryzen 5 7430U, 16GB+512GB] for $371 —was $439 (15% off) GEEKOM A6 [Ryzen 7 6800H, 16GB+1TB] for $524 —was $649 (19% off) GEEKOM A7 MAX [Ryzen 9 7940HS, 16GB+1TB] for $594 —was $699 (15% off) GEEKOM A9 MAX [Ryzen AI 9 470 HX, 32GB+2TB] for $1,444 —was $1,699 (19.72% off) GEEKOM IT13 MAX [Intel U9 185H, 16GB+2TB] for $764 —was $899 (15% off) Please be aware that the above promotional discounts expire on June 26 Between June 23 - 26 it's Prime Day week on Amazon, click here to check out all the deals. As an Amazon Associate we earn from qualifying purchases.
      nates earned a badge
      Almohandis earned a badge
      dorf went up a rank
      mike_rumble earned a badge
      tuben earned a badge
