Popular Corsair 4000D white PC case with high airflow and great cable management is cheap
Get Corsair's popular Frame 4000D Airflow case for its lowest ever price. This cabinet also helps with easy cable management.
Getting decently priced memory at the moment is almost impossible due to high prices, which is why we have been posting some really good combo bundle deals that pair up RAM and motherboards. Keep an eye on those, as we have a feeling they too may dry up sooner rather than later.
Meanwhile, if you are hunting for a case that is white, then Corsair’s Frame 4000D Airflow is a very good option, as it is one of those mid-tower cabinets that manages to balance clean looks with great cooling, and currently it is a very low price of just $81 (purchase link under the specs table down below).
corsair frame 4000d airflow white PC cabinet
As with other cases, the Frame 4000D Airflow comes with a tempered glass side panel, but it has a meshed front optimized for ventilation and features Corsair’s RapidRoute cable management system, and more.
For anyone unfamiliar with it, RapidRoute is a built‑in cable management feature in Corsair PC cases that provides pre‑designed channels and tie‑down points to make cable routing faster, cleaner, and more convenient. It’s designed so you can tuck cables neatly behind the motherboard tray, which can help both in aesthetics and in airflow by lowering turbulence.
Alongside that, Corsair’s FRAME Modular Case System offers a fully modular mid‑tower design, allowing users to customize layouts for airflow, cooling, and component clearance. It supports dual 360 mm radiators, reverse‑connector motherboards, and includes features like GPU anti‑sag arms. Meanwhile, the InfiniRail Fan Mounting System complements this by replacing fixed fan holes with sliding rails, letting users position 120 mm or 140 mm fans exactly where needed.
The technical specifications of the Corsair Frame 4000D White case are given in the table below:
Specification Value
Case Dimensions 466 mm x 230 mm x 453 mm
Maximum GPU Length 400 mm
Maximum PSU Length 220 mm
Maximum CPU Cooler Height 170 mm
Expansion Slots 7 horizontal + 2 vertical
Case Drive Bays 2 x 2.5 in SSD, 2 x 3.5 in HDD
Case Material Steel, Tempered Glass, Plastic
Radiator Compatibility Front: 120 mm, 140 mm, 240 mm, 280 mm, 360 mm
Top: 120 mm, 240 mm, 280 mm, 360 mm
Rear: 120 mm
Fan Compatibility Front: 3 x 120 mm or 2 x 140 mm
Top: 2 x 120 mm or 2 x 140 mm
Rear: 1 x 120 mm
Included Fans 3 x 120 mm ARGB fans
Front I/O Panel 1 x USB 3.1 Type-C, 1 x USB 3.0, Audio In/Out
Compatibility ATX, Micro-ATX, Mini-ITX motherboards
Special Features FRAME Modular Case System, CORSAIR InfiniRail Fan Mounting System, GPU Anti-Sag Bracket
Get it at the link below:
If you don't like it or want to look at more options, check out the previous deals that we have covered, OR you can also visit Amazon US deals page.
ebook offer
[Free download] Unified SecOps Playbook (worth $39.99)
microsoft outlook in red indicating bug or flaw
Microsoft makes Outlook "completely unusable" as Windows 11 25H2/24H2 update breaks it [Update]
4 Comments
