Thanks to HISgadget for providing me with these samples to review.
Lets start with the speaker coming in at £22.99.
Features:
  • Speaker - Full range 45mm
  • RMS - 5W
  • Bluetooth Chipset - CSR
  • Bluetooth Version - V4.0
  • Sensitivity - 80db
  • Distortion - 0.3%
  • Frequency Response - 90HZ - 18KHz
  • Battery - Built in 500 mAh Li-polymer battery
  • Size - 64.5 x 64.5 x 70.1mm (L X W X H)
  • Weight - 261g
Packaging:
The speaker arrives in a basic looking box with some foam protection to protect it from bumps/drops. Along with the speaker we also get 3.5mm audio jack cable and a micro USB cable.
The Speaker:
The first thing that you notice when taking the speaker out of the box is the premium feel to the device, it has a nice hefty weight (261g) to it and a very stylish premium polished metallic (zinc alloy) body design, overall it looks and feels great (although it is a bit of a fingerprint magnet), there is no flexing or creaky plastic when applying a bit of force to it. However, whilst it looks great, it has come at the cost of practicality, more on this later....
The speaker is pretty tiny overall, you could easily fit it in your laptop bag, rucksack etc. Here is a photo comparing it to an average sized mug:
On the front of the device, we have the bluetooth disconnect and answer/reject call button;
  • to disconnect bluetooth - press and hold it for 3 seconds
  • to answer a call - short press for 1 second
  • to reject a call - long press for 3 seconds
And just above that button, we have the mic.
On the back of the device we have the AUX-in jack port, micro USB port (for charging the device) and a LED indicator to indicate if the battery is low, it will do this by flashing red.
rzt2VZth.jpg?1
On the top of the device, we have the speaker grill.
On the bottom of the device we have the controls for music (pause/play, next and previous track buttons and you can increase or decrease the volume by holding down the previous and next track buttons) and the power on/off slider. We also have a rubbery surface to stop the device from sliding around as well as protecting your table from scratches, it also helps with dampening the sound.
The bluetooth wireless range is very good (HISgadget state a range of up to 33 feet!), I had to go to the other end of my house in order for the speaker to break up so you will have no problems in this area.
Audio Quality:
It is extremely easy to connect to this device using bluetooth, you just need to pair the device with your phone/tablet and that is it, you are good to go.
I wasn't expecting much from this speaker at first, however, I was pleasantly surprised, it gets very loud with no distortion and has good sound quality overall, perhaps a little bit muffled, quite a bit of bass (maybe a bit too much for my liking) and decent enough clarity. Overall it is much better than my nexus 5, moto g speaker and even my nexus 7 2013 tablet stereo speaker, however, my nexus 7 2013 has better clarity.
The only downside is that you can hear white noise (regardless of what the volume level is set too or what you are listening to/watching), for some this might be a bit off-putting, personally it bothers me quite a bit as it is one of those things that once you notice, you will always notice it.
In the user manual, it is stated to turn off wifi to improve the sound quality, however, there was no difference to my ears likewise with using wireless VS AUX/3.5mm cable.
There doesn't seem to be any obvious issue with the audio and video sync.
As for the call/speaker quality when it comes to phone calls, voices are clear enough but are bit muffled compared to my nexus 5 and moto g, as for how I sounded using the mic. on the wireless speaker, it was useless, I had to practically speak right into the mic. and even then people said I was still rather quiet, looking at other user reviews, this appears to just be a problem with my sample though as the majority say that the mic. has decent range and people only had issues hearing when the mic/speaker was more than 2 foot away from the person. Thankfully this isn't an issue for myself though since I never use loudspeaker.
Here is a video comparing the nexus 7 2013 speaker and the iclever speaker using the avengers age of ultron trailer on youtube:
Of course in real life, the speaker of both devices will sound much better than in this video.
Conclusion:
This is a fantastic little speaker that improves the sound experience a lot, it is hard to use my nexus 5 speaker for music and youtube videos now due to the difference! However, for the likes of the HTC one phones, which have boomsound/front facing stereo speakers, there is no reason to use this or any other wireless speaker.
I feel that HISgadget could have done a lot better with the design of this speaker though, whilst it is nice looking, the placement of the controls etc. don't make any sense, in my opinion, they should have:
- placed the controls on the top of the device, that way, you don't have to lift the device every time you want to pause/play a song or change the track
- placed the battery indicator on the front/top as I have no idea if the speaker needs charging until it dies or constantly check the back or I could just turn it around to have it facing me but then the bluetooth/answer/reject button and mic. are facing away from me....
Regarding the battery life, it is estimated that you should get 8-12 hours of playtime and so far with my usage that is looking to be true (I keep the volume set to just below half way)
As for the price, I feel that it is pretty fair, there are other similar speakers out there for a bit cheaper, however, their specs. aren't quite as good as this + the design, build and feel doesn't look anywhere as good as this iclever speaker!
Now onto the fast 6 USB port charger, which comes in at £19.99!
Packaging:
The charger arrives in a very minimal box, inside we have just the charger and the power lead.
The charger:
Overall it fairly basic looking, most of the body has a matte plastic finish with a glossy plastic finish on the front and back. On the front at the top, we have a tiny green LED indicator.
At the front we have the 6 USB ports, inserting and removing USB cables is a little stiff, however, they should loosen up in time.
The charger is rather small, here is a photo of it next to an average sized mug:
The dimensions are: 100 x 69 x 27mm (L X W X H) and the weight is 180g.
I don't have 6 devices to make use of this charger but it is great to be able to free up 3 wall sockets so I can only imagine how handy this would be for people with 6 devices!
As for the charging speed, I started charging my nexus 5 when it had 20% left:
  • Using the default nexus 5 charger/adapter - it took 2 hours and 17 minutes to fully charge
  • Using this 6 port usb fast charger - it took 1 hour and 32 minutes to fully charge
So as you can see, quite the improvement!
One fairly annoying issue though... coil whine, for some reason, there is coil whine when only charging one device, however, if you charge 2+ devices at the same time, then the coil whine disappears, I tried different ports, different cables, devices etc. but it was always the same result.
Conclusion:
Overall this is a fantastic little device, it is sleek looking, very portable, charges devices quicker than the default chargers, frees up wall sockets and doesn't cost too much. Apart from the coil whine when charging one device, which is quite common with most charger devices anyway, there isn't really much to dislike about it except the glossy plastic finish....
    • Microsoft Weekly: Surface Laptop Ultra, Windows 11 context menus, Build 2026 recap, and more by Taras Buria This week's news recap is here, with Microsoft announcing the new Surface Laptop Ultra, fresh chips from NVIDIA for Windows on ARM, a no-build week, fixes for Windows 11's context menus, gaming news, reviews, and more. Quick links: Windows 10 and 11 Windows Insider Program Updates are available Reviews are in Gaming news Great deals to check Windows 11 and Windows 10 Here, we talk about everything happening around Microsoft's latest operating system in the Stable channel and preview builds: new features, removed features, controversies, bugs, interesting findings, and more. And, of course, you may find a word or two about older versions. At Computex 2026, together with NVIDIA, Microsoft announced the Surface Laptop Ultra, its most powerful laptop to date, powered by NVIDIA's RTX Spark processor. Details about this computer are currently scarce, as Microsoft has only revealed certain parts of its specs. So far, we know that the computer has a 15-inch mini-LED display, a rich set of ports, a powerful processor, and all-day battery life. It also comes with a new wallpaper, which you can already download here in full resolution. The Surface Laptop Studio is not the only NVIDIA-powered Surface, which Microsoft unveiled this week. At Build 2026, the company also debuted the Surface RTX Spark Dev Box, an odd-shaped desktop with a 20-core NVIDIA Grace CPU and an NVIDIA Blackwell RTX GPU with 6,144 CUDA cores and fifth-generation Tensor Cores with FP4 precision, connected via the NVIDIA NVLink-C2C chip-to-chip interconnect for high performance. According to Microsoft, it can run models with up to 120 billion parameters locally without relying on cloud GPU infrastructure. These two new Surface devices are likely to cost quite a lot, and for those who need a more affordable device, Microsoft is preparing the next-gen Qualcomm-powered Surface Pro and Surface Laptop. This week, details about these two devices leaked in plenty of detail. Other announcements at Build 2026 include the following: Microsoft unveils new security tools for IT admins and developers building AI products Microsoft announces Scout, an OpenClaw-powered personal agent for enterprise customers Microsoft unveils MAI-Thinking-1 reasoning and MAI-Code-1 coding models Microsoft announced a new Windows 11 native command-line utility Microsoft unveils Majorana 2 quantum chip, accelerating commercial timeline to 2029 Microsoft believes that AI agents will eventually replace apps through Project Solara Microsoft introduces Web IQ, a Bing-powered search system built for AI agents Last week, Microsoft released a new Experimental build, which introduced a major Start menu upgrade. It now lets you toggle off specific parts of the menu without affecting other features, resize the menu, and hide additional UI elements. We published a closer look here, so if you want to know what Microsoft is cooking without enrolling in the Insider program and installing unstable builds, check it out. Speaking of new features, many users are very annoyed about the way Microsoft delivers them. Recently, a frustrated user shared their experience with gradual rollouts, and even Microsoft engineers admitted there is a flaw in the system that prevents new features from applying properly. One of those new features includes the ability to uninstall AI models in Windows 11 with a single click. Windows 11 is finally getting fixes for its slow context menus. Marcus Ash from Microsoft confirmed that the company is working on fixing Windows 11's context menus. Reworked context menus are going to be faster, simpler by default, and "configurable to what you use most." According to Marcus, Microsoft will share more details soon. Windows Insider Program Windows 11 preview builds, released last week, are now available for download as standalone ISO files. These days, Microsoft regularly pushes new images, allowing users to clean-install its recent Windows 11 preview builds faster and easier. If you want to try the latest Windows 11 features without jumping through the Windows Update hoops, get those new images here. Sadly, Microsoft did not release new Windows 11 preview builds this week. Come back next time. Updates are available This section covers software, firmware, and other notable updates (released and coming soon) delivering new features, security fixes, improvements, patches, and more from Microsoft and third parties. Microsoft is preparing new features for Teams. Later this month, the messenger will receive a new download manager with auto-dismissing notifications, reducing clutter and making the overall experience less annoying when dealing with downloads. Mozilla released Firefox 151.0.3, a new bug-fixing update for the browser. It is a small release, which fixes problems with pasting into text fields and the oversized VPN button on the toolbar. The update is now available for all users in the Release channel. Here are other updates and releases you may find interesting: VS Code 1.123 introduces massive upgrades for persistent AI developer workflows Microsoft OneDrive is getting a simple yet much-needed feature Microsoft faces heat after quietly blocking promised Office features on Apple systems Microsoft resumes forced Copilot app installation on some Windows PCs Browser vendors pen an open letter to Microsoft, saying "enough is enough" Here are the latest drivers and firmware updates released this week: AMD Radeon Software 26.6.1 with optimizations for F1 25: 2026 Season, World of Tanks: HEAT, and various bug fixes. Reviews are in Here is the hardware and software we reviewed this week Steven Parker dropped more mini PC reviews this week. GEEKOM Air12 2026 Edition is a low-power, affordable computer with an Intel Tiger Lake Pentium Gold processor, up to 16GB of memory, and 512GB of storage, costing just $349. It is light, quiet, energy efficient, and has modern ports on the front. However, the front-facing USB Type-C is data-only, and there are some quirks with the computer's memory, so check out the full review. The AMD RX 9070 GRE has been released worldwide, and we published a benchmark review comparing this powerful graphics card to the RX 9070 XT, 7800 XT, the NVIDIA RTX 5070, and RTX 4070. It has solid, balanced performance, plenty of RAM, and low temperatures, but watch out for mediocre ray tracing performance and not the best efficiency. Also, we reviewed the Cuktech 10 Ultra, a compact, high-power charger with four ports and a big display full of various stats. This tiny charger can pull nearly 120W and spread that power according to each connected device's needs. It also comes with a high-quality 240W cable, three power modes, and retractable prongs. The best part? It is quite affordable, just make sure you have an outlet placed in the right spot to benefit from the built-in display. On the gaming side Learn about upcoming game releases, Xbox rumors, new hardware, software updates, freebies, deals, discounts, and more. Do you remember the ASUS ROG Xbox Ally, Microsoft's first handheld console designed in partnership with ASUS? This week, ASUS revealed a new version of the device to celebrate twenty years of its Republic of Gamers brand. The new ROG Xbox Ally X20 features an OLED display, a transforming D-Pad, TMR sticks, and other changes. However, the chip inside the console is still the same. Forza Horizon 6 launched last month to critical acclaim, but the game will soon have a new rival made by those who used to work on Forza Horizon titles. Mike Brown from Maverick Games announced Clutch, an upcoming racing game with a story-driven campaign, deep car customization, and rich multiplayer. The game is coming to PC, Xbox Series X|S, and PlayStation 5 in Spring 2027. The next update for Minecraft now has a release date. This week, Mojang announced that Chaos Cubed will be available on June 16, 2026. In addition, Mojang published a teaser of the next Minecraft movie. A Minecraft Movie Squared has now been confirmed for a release somewhere in 2027. NVIDIA GeForce Now is getting 18 new games in June. Those include Jurassic World Evolution 3, Fatekeeper, GOALS, Gothic 1 Remake, NTE: Neverness to Everness, and more. If you are a Game Pass subscriber, you can also get new games soon: Persona 5 Royal, Starseeker: Astroneer Expeditions, and more are coming to the service this month. Sumer Game Fest 2026 happened this week, where we saw plenty of new games, including Alien Isolation 2, Final Fantasy VII Remake Part 3, Gen Atlas from the Shadow of the Colossus creator, a new Cuphead game in 8-bit style, a new expansion for Mafia: The Old Country, and more. Finally, here are this week's Weekend PC Game Deals, full of discounts and the latest freebies from the Epic Games Store. Other gaming news includes the following: God of War Laufey announced, introducing Kratos' wife as the new protagonist Ori studio's No Rest for the Wicked 1.0 release and console plans announced Microsoft launches Godot Sample to streamline Xbox PC game development on the engine Great deals to check Every week, we cover many deals on different hardware and software. The following discounts are still available, so check them out. You might find something you want or need. Samsung 990 PRO SSD 2TB NVMe - $389.99 | 39% off Sonos Sub 4 - Wireless Subwoofer - $759 | 16% off Logitech MX Creative Console - $159.99 | 20% off This link will take you to other issues of the Microsoft Weekly series. You can also support Neowin by registering for a free member account or subscribing for extra member benefits, along with an ad-free tier option.
    • Let's goooooooo! I've been loving the entries so far! I still have to finish Rebirth (things have been busy!)! Excited for this next installment.
    • "Revelation?" I was hoping for this episode to be called "Reunion". Oh, well... In a related note, the Final Fantasy VII compilation has received an EC entry, short for Ever Crisis. For those who don't know, it already had AC, BC, CC, and DC entries, short for Advent Children, Before Crisis, Crisis Core, and Dirge of Cerberus. I hope it doesn't get an FC entry becaude that would be a freakin' crisis.
      pestcontrol46 earned a badge
      JKR earned a badge
      moog19 went up a rank
    • Mentor
      grik went up a rank
      Mentor
      Skyfrog
      76
